How to print enumerated signal to file in VHDL testbench?
design_engineer
Newbie level 6
Hello,
I have a signal defined as an enumerated type in my design.
type state is (idle, start, run, end);
signal t_state is array (3 downto 0) of state;
How do I print the value of this signal to a file during my simulation?
When I do
write(line_out, t_state) or write(line_out, t_state(0))
I get argument type mismatch error during compilation.
Please help.
shawndaking
Full Member level 3
Re: How to print enumerated signal to file in VHDL testbench
you can assign values to everything :
for example :
dbg_p : process (clk)
begin
if rising_edge(clk) then
new_arb_sm_dff <= new_arb_sm;
case new_arb_sm_dff is
when IDLE => pkt_arb_state_dbg <= "000";
when NPI_REQ => pkt_arb_state_dbg <= "001";
when GNT_ASI_0 => pkt_arb_state_dbg <= "010";
when GNT_ASI_1 => pkt_arb_state_dbg <= "011";
when GNT_IP => pkt_arb_state_dbg <= "100";
end case;
end if;
end process dbg_p;
