xplicitone
Newbie level 1
Hello,
I'm trying to print characters at particular locations on the LCD of the Spartan 3e using Verilog. I've initialized it, but can't seem to print characters where I want to on the board.
Thank you.
Added after 10 minutes:
Here is my initialization code. I'm trying to display numbers in particular spots on the LCD, for example.
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 01:14:32 02/24/2010
// Design Name:
// Module Name:
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module LCD(LCD_RS,LCD_RW,LCD_E,LCD_DATA,inclk,outclk);
output LCD_RS,LCD_RW,LCD_E;
reg LCD_RS,LCD_RW,LCD_E;
output [3:0] LCD_DATA;
reg [3:0] LCD_DATA;
input inclk;
reg [3:0] Init_List[33:0]; //This creates 12 - 4 bit memory locations
//reg [3:0] Char_List[21:0]; //This creates 12 - 4 bit memory locations
integer counter;
reg done;
integer count;
output outclk;
reg outclk;
reg [1:0] state;
integer sec0;
integer sec1;
integer min0;
initial
begin
sec0 = 12; //for 0 on array below
sec1 = 12;
min0 = 12;
state = 0;
count = 0;
outclk = 0;
counter=0;
done=0;
Init_List[0]=4'b0011; //Init
Init_List[1]=4'b0011;
Init_List[2]=4'b0011;
Init_List[3]=4'b0010;
Init_List[4]=4'b0010;
Init_List[5]=4'b1000;
Init_List[6]=4'b0000;
Init_List[7]=4'b0110;
Init_List[8]=4'b0000;
Init_List[9]=4'b1100;
Init_List[10]=4'b0000;
Init_List[11]=4'b0001;
Init_List[12]=4'b0011; //0
Init_List[13]=4'b0000;
Init_List[14]=4'b0011; //1
Init_List[15]=4'b0001;
Init_List[16]=4'b0011; //2
Init_List[17]=4'b0010;
Init_List[18]=4'b0011; //3
Init_List[19]=4'b0011;
Init_List[20]=4'b0011; //4
Init_List[21]=4'b0100;
Init_List[22]=4'b0011; //5
Init_List[23]=4'b0101;
Init_List[24]=4'b0011; //6
Init_List[25]=4'b0110;
Init_List[26]=4'b0011; //7
Init_List[27]=4'b0111;
Init_List[28]=4'b0011; //8
Init_List[29]=4'b1000;
Init_List[30]=4'b0011; //9
Init_List[31]=4'b1001;
Init_List[32]=4'b0011; //:
Init_List[33]=4'b1010;
end
always @(posedge inclk) //slowing down the clock
begin
if (count >= 2500000)
begin
count = 0;
outclk = !outclk;
end
else
begin
count = count + 1;
end
end
always@(posedge outclk)
begin
LCD_RW=0; //write mode always
if (counter < 12)
LCD_RS=0; //command mode
else
LCD_RS=1; //data mode
LCD_DATA=Init_List[counter]; //putting data on a bus
if (! done)
begin
LCD_E = 1;
done = 1;
end
else
begin
//Once counter reaches 11, the LCD is ready to receive ASCII data
case (state) // switch based on control signals
0:
begin
if (counter < 11)
begin
LCD_E = 0;
done = 0;
counter = counter + 1;
end
else
state = 1;
end
1:
begin
if (sec0 < 31)
begin
counter = sec0;
sec0 = sec0 + 1;
LCD_E = 0;
done = 0;
end
else
begin
sec0 = 12; //0 sec reset
counter = sec0;
LCD_E = 0;
done = 0;
state = 2;
end
end
2:
begin
if (sec1 < 23) //5 secs
begin
counter = sec1;
sec1 = sec1 + 1;
state = 1;
end
else
begin
sec1 = 12; //0 secs
counter = sec1;
state = 3;
end
end
3:
begin
min0 = min0 + 1;
state = 1;
end
//counter = counter + 1;
endcase
end
end
endmodule
Thank you.
// Company:
// Engineer:
// Design Name:
// Module Name:
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
reg [3:0] LCD_DATA;
input inclk;
integer counter;
reg done;
integer count;
output outclk;
reg outclk;
reg [1:0] state;
integer sec0;
integer sec1;
integer min0;
initial
begin
sec1 = 12;
min0 = 12;
state = 0;
count = 0;
outclk = 0;
counter=0;
done=0;
end
begin
begin
count = 0;
outclk = !outclk;
end
else
begin
count = count + 1;
end
end
begin
if (counter < 12)
else
if (! done)
begin
LCD_E = 1;
done = 1;
end
else
begin
0:
begin
if (counter < 11)
begin
LCD_E = 0;
done = 0;
end
else
state = 1;
end
1:
begin
if (sec0 < 31)
begin
counter = sec0;
sec0 = sec0 + 1;
LCD_E = 0;
done = 0;
end
else
begin
counter = sec0;
LCD_E = 0;
done = 0;
state = 2;
end
end
2:
begin
begin
counter = sec1;
sec1 = sec1 + 1;
state = 1;
end
else
begin
sec1 = 12; //0 secs
counter = sec1;
state = 3;
end
end
3:
begin
min0 = min0 + 1;
state = 1;
end
endcase
end
end
endmodule
