ruwan2
Member level 5
- Joined
- Nov 29, 2011
- Messages
- 90
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 2,141
I read a Verilog tutorial on numeric expression. The example is:
The result is:
# $display: A1 = 1111111111111100, A1 = 65532
A1 is -4, but the print is '1111111111111100', or '65532'. It is different from the picture shows.
I find the following but not sign control here.
It should be able to print '-4' as the picture show. Could you tell me that? Thanks,
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 integer intA; reg [15:0] regA; always @ * begin intA = -4'd12; $display ("\$display: A0 = %b, A0 = %d", intA, intA); // regA = intA / 3; $display ("\$display: A1 = %b, A1 = %d", regA, regA); //
The result is:
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 $display("<format>", exp1, exp2, ...); // formatted write to display format indication %b %B binary %c %C character (low 8 bits) %d %D decimal %0d for minimum width field %e %E E format floating point %15.7E %f %F F format floating point %9.7F %g %G G general format floating point %h %H hexadecimal %l %L library binding information %m %M hierarchical name, no expression %o %O octal %s %S string, 8 bits per character, 2´h00 does not print %t %T simulation time, expression is $time %u %U unformatted two value data 0 and 1 %v %V net signal strength %z %Z unformatted four value data 0, 1, x, z
