How to prevent a module from synthesis in FPGA flow
tariq786
Advanced Member level 2
USA
Hi guys,
Hope you are good.I have couple of modules in a hierarchy. That is
TopModule
-----> module 1
-----> module 2
-----> module 3
I want to synthesize all modules including TopModule except module3. How to prevent module3 from synthesizing, translating, mapping and P&R.
Any ideas!!!
Thanks
You should not instantiate module 3 in your topmodule.
Hey Zula,
Then how is the overall system going to work?
are you using xilinx or altera...?
If you are using Xilinx then refer to incremental synthesis feature ...
refer to dev guide or **broken link removed**
Your problem isn't clear. You don't want to be synthesized your module and you want whole system is goin' to work properly. If module 3 isn't going to be there, how can it affect your system..
Do you want to use module 3 or not? If you don't want this module in your design, you won't instantiate it..
In Verilog, there is conditional compilation. You may look for it..
Good Luck..
Ilgaz
I agree with Ilgaz, that you should tell the purpose of omitting a module from synthesis.
As an additional remark, at worst case simply omitting the module instance can result in no logic synthesized for the top design.
If you are intending a kind of top town design (coding the lower modules later), you may want to insert a dummy module that
"consumes" input signals and generates output at the interface. Unfortunately, the dummy module implicitely constraints
the other module's timing, so the logic should be well considered.
HI,
make use of define.v file
Reffer to attached file
if commnetout `define INCLUDE_MODULE_4 line in define.v module_5 will be synthesize else module_4 will besynsthesized
HTH
Shitansh Vaghela
