lizxay
Newbie level 2
Hi everyone, I have written my coding to count the revolution per minute of a motor, does anyone know how to pass the counted value to lcd? how to write it ? my coding is below, i really need u guys help, thanks a lot, if u guys feel it's too long, u can straight jump to the void value() part, it's that part i need help =)
#include<pic.h>
__CONFIG(0x3f18);
//__CONFIG_DEBUG_0FF&_CP_ALI&_WRT_HALF&_CPD_ON&_LVP_0FF&_BODKN_OFF&_PWRTE_ON&_WDT_OFF&_HS_OSC
#define rs RA0
#define rw RA2
#define e RA1
const char label[]={' ','S','P','E','E','D',':'};
const char unit[]={'R','P','M',' '};
void start();
void delayloop();
void init(); //I/O port initialize function declare
void lcd_init(); //LCD init
void write_label();
void write_unit();
void write(char x); //display one byte
void lcd_enable(); //LCD display setting
void delay(); //delay
void main(){
while(1){
start();
RA2=1;
init();
lcd_init();
write_label();
PORTB=0xC0; //set the 2nd line display address
write_unit();
void start(){
int timerstart,timerstop,count,duration,rpm;
STATUS=STATUS&0b00100000;
TRISA=0x04;
TRISB=0x00;
T1CON=0b00101101;
STATUS=STATUS&0b00000000;
PORTA=0x00;
PORTB=0x00;
start:
if(PORTA&0b00000100){
goto input;
else{
goto start;
input:
timerstart=TMR1H;
delayloop();
start2:
goto input2;
else{
goto start2;
input2:
timerstop=TMR1H;
delayloop();
if(timerstop > timerstart){
duration=timerstop-timerstart;
else{
duration= timerstop + 60 - timerstart;
rpm=60/duration;
void delayloop()
int i;
for(i=0;i<5000;i++);
//initialize I/O
void init()
CMCON=0x07;
TRISA=0x00;
TRISB=0x00;
//LCD init
void lcd_init()
PORTB=0x1; //clear screen
lcd_enable();
PORTB=0x38; //8 bits 2 lines 5*7 mode
lcd_enable();
PORTB=0x0e; //display on, cursor on, blink on
lcd_enable();
PORTB=0x06; //character not move, cursor rotate right
lcd_enable();
PORTB=0x80; //www.ahchye.com
lcd_enable();
void write_label()
int i;
for(i=0;i<0x07;i++)
write(label); //search table
void write_value()
"THIS PART IS TO WRITE AND PASS THE RPM VALUE"
void write_unit()
int i;
for(i=12;i<0x0F;i++)
write(unit);
//write a byte to led
void write (char x)
PORTB=x; //data send to PORTB
rs=1; //is data not command
rw=0; //is write not read
e=0; //pull low enable signal
delay(); //for a while
e=1; //pull high to build the rising edge
//lcd display setting
void lcd_enable()
rs=0; //is command not data
e=0; //pull low enagle signal
delay(); //for while
//delay
void delay()
int i;
#include<pic.h>
__CONFIG(0x3f18);
#define rs RA0
#define rw RA2
#define e RA1
void start();
void delayloop();
void write_label();
void write_unit();
void main(){
while(1){
start();
RA2=1;
init();
lcd_init();
write_label();
write_unit();
void start(){
TRISA=0x04;
TRISB=0x00;
T1CON=0b00101101;
PORTA=0x00;
PORTB=0x00;
start:
goto input;
else{
goto start;
input:
timerstart=TMR1H;
delayloop();
start2:
goto input2;
else{
goto start2;
input2:
timerstop=TMR1H;
delayloop();
else{
rpm=60/duration;
void delayloop()
int i;
//initialize I/O
void init()
CMCON=0x07;
TRISA=0x00;
TRISB=0x00;
//LCD init
void lcd_init()
lcd_enable();
lcd_enable();
lcd_enable();
lcd_enable();
lcd_enable();
void write_label()
int i;
for(i=0;i<0x07;i++)
void write_value()
void write_unit()
int i;
write(unit);
void write (char x)
void lcd_enable()
//delay
void delay()
int i;
