[SOLVED] How to move data between two clock domains.
3wais
Member level 4
Alexandria,Egypt
How to move data between different clock domains? possibly Single and Double data rates too.
I know a dual clock FIFO could be used for that purpose. but it is not needed!!
the design is a counter running in one clock domain and writing the value to a register, and the value is read in another domain. it is more of a dual clock register if I could say so!!
How could something like this be done? a whole FIFO is not needed and will just be a waste of resources.
instead used double flop synchronisation for all the values registers, you could only do that for a ready signal, which indicate the registers is stable and couldbe read by the other clock domain, that reduce the power and area.
Reactions: 3wais
    3wais
Thanks for the tip, After searching I came across that pdf which I found very useful.
It may help whoever faces the same issue.
