To see the voltage at node 2 change, you can connect node 2 to a current source, or to a voltage source by a resistor. Don't leave it float, neither connect it to a voltage source directly.
You need to specify a voltage value greater than zero for vs. Otherwise, you will not have any current flowing through the switch and the voltage at node 2 will not change.
