Hi Beepster,
yes, you are right, but i found in the help of the PowerPCB/BlazeRouter keyword"Intensity"and the following statments are written in the software help:
Intensity is a value assigned to objects such as vias to weigh decisions made during the autorouting process in BlazeRouter. The higher the intensity, the less the item is used. For example, set a high intensity for via usage to minimize the amount of vias added to the design.
So,have an idea where can i find this feature instead of manual Routing?
