dovod
Newbie level 6
- Joined
- Sep 26, 2014
- Messages
- 11
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 107
Hi all,
I was wondering if this is possible. I have modelled a 3d structure of a Horn antenna in CST MWS 2014 and the whole thing (with a considerable thickness in order to have screws through it and have a model easy to print in a 3D printer) is made out of gold. The thing is I just need the internal faces to be metallized, as it will work as a pec, I don't mind the exterior to be metallized and besides, I think the simulation is giving some wrong outcomes if the whole thing is made out of gold.
So, do anyone know how to select the internal faces and change the material only on that selected zones? Is it even possible? Thank you all.
P.D.: The error I get in the results is that the resonance frecuency is a bit shifted to higher frequencies comparing to what I get with the horn antenna without all the apparatus, just to let you know if this may have another explanation...
Thank you all in advance!
