shengwuei
Newbie level 3
I need to do impedance matching between PA(300W, 10~50MHz) and load.
In my case, neither the impedance of PA nor the load is 50 Ohm, so my plan is to measure the impedance of both of them and do conjugate matching base on my measurement.
The problem is since PA output power is high, I cannot use a VNA to measure PA output impedance directly. I googled some posts and tried to add an attenuator between PA and VNA to do the measurement, though the measured result is always 50Ohm if attenuator is present. If I do VNA calibration with the attenuator , the reading of VNA would be totally wrong after calibration,so I think this is just not a right way to do this.
There are also some posts describing how to use a directional coupler or two different loads to do the measurement, but I cannot fully follow up those procedure because I am not an experience guy in RF area. I need some detailed suggestion, please help, thanks a lot !![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
