yellowtooth
Full Member level 3
Recently, I met a problem that the return loss is not as good as expected.
Maybe the connector on our PCB is not 50ohm.
One port of the connector is N type, the other port is not standard type, something like coaxial cable.
And I cannot connect two connectors together to form a two N type ended connector.
So I can only connect one of them to the vector network analyzer's prot1 to measure S11 or Zin. While the other port is just let open ended.
I wonder how to know if it has 50ohm characteristic impedance.
Please tell me if you know.
thank U.
thank U.
