Note: This feature currently requires accessing the site using the built-in Safari browser.
I've design an adapter which convert from N-type female to "X" type.
N type is 50 Ohm
X type desired 75 ohm.
But how to measure the impedance of X-type?
Thanks,
Just calibrate a Network Analyzer with N-Type SOL Cal kit, then connect your adapter and
terminate it with a 75 Ohm Load on the X Conn. Then Measure the S11. This will give you an
accumulated match. If it shows bad performance you will have to determine if there is a Bad "N"
design, a bad "X" Design or a bad "75 Ohm" Load. But if you get a VSWR of better than >-40dB
you can assume it's a decent design, and could safely used for most tests with exceptions to very
hard, sensitive tests.
Note the Minimum Loss for a 50-75 Ohm conversion is 5.75dB, so your design should have that much loss.
Just get the mate to your X-Connector and solder 2 small (As Possible) 150 Ohm resistorsThat's great. you've my point. X-type is my own design.
But I can not find 75 Ohm load to connect to X Connector.
Is there any way to buy/manufacture 75 terminator for customized connector?
Thanks
Your answer clarifies that the problem is still rather vague. As already mentioned, the term "impedance of connector" is dubious itself. If you say, you have designed a custom 75 ohm connector, I presume you have a specification, e.g. VSWR < value x in a frequency range y to z. If you know to design a coaxial connector, why can't you design a termination for it?My X-type connector has diameter of 34mm, I suspect the accurancy of your method. Because it doesn't cover the perimeter of the connector.
