how to make the timer in windows form application work one by one with button click
hari516
Newbie level 6
Mumbai
hi,
I just want to enter the timer duartion of three solenoids in three text boxes and click the button called invert operation.The resultant suppose to be enable the corresponding LED in board till the first text box time duration and then it has to consider second timer duration then have to enable the corresponding LED and so on..Is it possible to do it.Hope i conveyed my idea properly..My problem was when ever i run the invert operation button it will consider the last textbox duration and LED high option.The process has to be sequentail..Can i do it ?? If so give me any suggestion to implement this..
 private void button1_Click_1(object sender, EventArgs e)//invert button
            int i;
            int[] txtvalue = new int[3];
            //invert.Enabled = false;
            for (i = 0; i < 2; i++ )
                if (i == 0)
                    try
                        txtvalue[0] = Convert.ToInt32(textBox1.Text);
                        txtvalue[0] = txtvalue[0] * 1000;
                        PortAccess.Output(888, 254);
                        solenoid1.Enabled = false;
                        Timer timer = new Timer { Interval = txtvalue[0] };
                        timer.Tick += timer1_Tick;
                        timer.Start();
                    catch (InvalidCastException ex)
                        throw (ex);
                        MessageBox.Show("Please Enter Numbers between 0-100");
               if (i==1)
                ////for second solenoid
                //try
                //    txtvalue[1] = Convert.ToInt32(textBox2.Text);
                //    txtvalue[1] = txtvalue[1] * 1000;
                //    solenoid2.Enabled = false;
                //    PortAccess.Output(888, 253);
                //    Timer timer1 = new Timer { Interval = txtvalue[1] };
                //    timer1.Tick += timer1_Tick_1;
                //    timer1.Start();
                //catch (InvalidCastException ex)
                //    throw (ex);
                //    MessageBox.Show("Please Enter Numbers between 0-100");
            ////for third solenoid
            //txtvalue3 = Convert.ToInt32(textBox3.Text);
            //txtvalue3 = txtvalue3 * 1000;
            //solenoid3.Enabled = false;
            //PortAccess.Output(888, 251);
            //Timer timer2 = new Timer { Interval = txtvalue3 };
            //timer2.Tick += timer2_Tick;
            //timer2.Start();
