kahjoo
Junior Member level 2
I have difficulty to drop the 16F685 to below 1mA even when I tried to get into the sleep mode.
Before goes to sleep mode, I've set the internal clock from 8MHz to 31KHz. Also disable all the setting before entering sleep mode.
The MCU was powered by 5V which having the 7805 regulator dropping 12V to 5V.
We target the MCU to have the uA current consumption as stated in datasheet.
Is that any setting that I've miss out to archive uA current consumption?
Thank You
Kah Joo
Thank You
Kah Joo
