How to make prototype PCBs using photosensitive PCBs?
techie
Advanced Member level 3
Pakistan
PCB prototype problem
I got some "presensitized PCB" from a DIY shop. These are smal pcs of PCBs that have some photosensitive coating on them. The coating is green in color and then there is a white sticker on top. The instructions are in a language that I dont understand. Can someone help me and describe the method how to make prototype PCBs using this type of photosentsitive PCBs.
Moss
Full Member level 3
Re: PCB prototype problem
Probably it depends in some degree from manifacturer. In general, procedure is
1. Print on transparent film your PCB project.
2.Remove protective adhesive laminate from the board.
3.place printed film on board
4. Expose board with UV lamp ( 300-400nm) for some time. In fact this is biggest problem, because you dont know for how long you shoud expose the board. You must try several times. Exposer time is somewhat about several minutes, depending on your UV lamp. Check google for " UV exposure box"
5.Develop board.
6.Etch.
This technology is not simple, but produce probably best results.
techie
Pakistan
thanks. i unerstand everything except How to develop after exposing . what chemical to use as a developer.
Moss
Full Member level 3
In general development is simple. You must prepare some solution, like it is shownhere. Just put the board in solution for about a minute There is a lot diferent developers on the market. Some people use NaOH, but result depedns from devlopment time quite strongly.
M!k
Advanced Member level 2
Moss said:
In general development is simple. You must prepare some solution, like it is shown here. Just put the board in solution for about a minute There is a lot diferent developers on the market. Some people use NaOH, but result depedns from devlopment time quite strongly.
concerning the caustic soda concentration etc. take a look at this thread:
Mik
