How to make pin numbers visiblein Orcad Capture CIS
Roel
Member level 2
Member level 2
Belgium
orcad pin numbers
How do you make the pin numbers of, for example a transistor, visible in your schematic.
I can' find it, either not in the Help files.
Roel
changing pin numbers orcad
edit component and change properties
6 * F
pin orcad capture
Hi
1) Select the component
2) RMB click edit part
3) Double click on the empty area ( edit properties)
4) You will see a property pin numbers visible = False , make this true, and update for that particular or all parts....
and the job will get done ..
Regards
Asterix
