how to make code not readable ?
omidsht
Member level 2
how to make codes
i have written a vhdl code , i want others to use it as a component but not able to read it (access the source) , what shall i do ?
i think if i could compile it in a library , my goal is achieved , but when i compile it in modelsim in my computer it is okay , but when i take it to other computer it is not working (says it is not bounded) !
any help ?
thanks in advance
omid
modelsim ngc
When you simulate, are these libraries properly referenced. There are switches like "-lib". Refer vsim command reference in modelsim.
modelsim code obfuscator
Hi
in which software you write your codes. you can synthesis your code then a file will generate in NGC format. you can use NGC file as black box in other codes. on your top module only thing that you need is that use an entity of your NGC and instantiate it.
Hamed
Make a technology based netlist. It will confine the code to a specific technology too.
hamed_sotoudi said:
Hi
Hamed
when i synthesis the instantiate file with ISE , it is ok .
but the problem is this :
in simulation with modelsim , in instantiation file , it says : it is not bounded (modelsim does not see the ngc file to reference it
now my problem is in simulation with NGC file !
