baileychic
Advanced Member level 3
How to make a lumen meter?
I am planning to make a lumen meter to measure lumen output of Power LEDs using PIC12F microcontroller.
Lumens are expressed in Lumens/Watt usually.
So, if I know the voltage acorss the Led and current through it then I can calculate LED power. If datasheet of LED gives Watts per lumen information then can I convert my calculated watts into Lumens?
If the LED datasheet doesn't have the information about Watt/Lumen or Lumen/Watt then how can I find out Lumen per Watt by only measuring LED voltage an dcurrent without using any sensor?
