How to load programs to DDR SDRAM?
ezzeldeen
Junior Member level 2
Hi All
i succeeded to connect the Microbalze with DDR SDRAM but
How can i load my program into the DDR SDRAM ?
thanks
ezzeldeen
ddr load
Hi All
Finally I solved my problem :D
I attached a pdf which explain the following:
and i attached the code in rar file
this code use EDK 9.1 on Spartan-3S500E starter Kit
thanks
salma ali bakr
Advanced Member level 3
Re: Load to DDR SDRAM
Hello,
Do you have the board file (.xbd) used in this example please?
Regards,
Salma
