plainman007
Junior Member level 3
I have bought a new UPS which i will be using only 3-6 times in a year. This is to be used with a pc which will only be used on the field to control some automation. The rest of the time the PC will just be shelved in storage. Now that means almost 3-4 months of just being in storage. If i just disconnect the UPS and store it will the Sealed Lead Acid battery which is inside get spoiled or die due to deep discharge ?
So what is the better solution, to leave it plugged into the ac mains always throughout the year, even without any load attached to it ? Some say this will cause the battery to heat up while others say its normal / better.
Some have suggested connecting some small appliance to it, like a bulb or something and to use it continuously.
Please give me some suggestions ?
Thanks
Thanks
