how to interface RTC with 8051
epple
can anyone tel me how can i interface rtc with microcontroller... i have no idea about it ... i need to use keypad for setting up time ... i ve to use rtc for timer ....
DS1307 RTC is interface using I2C interface.
you have set time and then start the clock..
later u can read the time
here is program which sets time and reads time using PC interface MAX232..
on hyperterminal
here u can find datasheet
  • Copy of rtc01.txt
but i need assembly language code
---------- Post added at 20:13 ---------- Previous post was at 20:10 ----------
i need to give time duration to micro-controller during which it will switch on light... for this thing i have to interface LCD keypad n rtc... key n LCD interfacing is done but am not getting how to interface this RTC ..... am using assembly language
if you see the book by mazidi or kenneth ayala they have explained how to interface rtc with code in a lucid manner
check **broken link removed**
you can get the code and circuit diagram for interfacing.. with video also.
