How to interface 8051 with Serial port
shahzadleo7
Junior Member level 3
8051 serial port
plz help me hopw to interface the ucontroller with serial port to interface with mobile phone
thanxs in advacne
srikanthsamaga
Full Member level 3
12°52′N 74°53′E
8051 serial interface
I think mobile Phone cannot be interfaced to the microcontroller using RS232, you should interface it by hacking its headphone cable..
shahzadleo7
8051 serial interfacing
but i is interfaced by Sony Ericsson T290
javad66
Newbie level 3
8051 serial port interfacing
you can use usb cable and conect micro to mobile to read & write memory card of mobile only .(I think)
robismyname
Full Member level 6
Central Florida
serial interface of 8051
shahzadleo7 said:
plz help me hopw to interface the ucontroller with serial port to interface with mobile phone thanxs in advacne
Sounds like an interestign project. I have some experience setting up the MCU port and crossbar for UART applications. Do you have the data sheet for the particular MCU you are using? Do you plan to connect your MCU to a PC a review the data in a hyperterminal session?
besthabit
Islamabad
serial cable interface of 8051 with mobile phone
void main()
initUART();
delay();
sendString("AT+CMGF=1"); // command to select text mode
sendChar(13);
delay();
sendString("AT+CMGS=\"0999999999\"");// here 09999999999 is recepient's number
sendChar(13);
delay();
sendString("Hello!"); // Hello! will be sent
sendChar(26);
sendChar(13);
PRATHIMA REDDY
Newbie level 2
HYDERABAD
ORG 0000H
MOV SCON,#50H
MOV TMOD,#20H
MOV TH1,#-3
SETB TR1
THIS IS THE CODE FOR SERIAL INITIALIZATION OF 8051 MICROCONTROLLER IN ASSEMBLY.
HOPE THIS HELPS YOU.
