[Synth 8-5535] port <sys_clk> has illegal connections. It is illegal to have a port connected to an input buffer and other components. The following are the port connections :
Input Buffer:
Port I of instance clkin1_ibufg(IBUF) in module <design_1_clk_wiz_1_0_clk_wiz>
Other Components:
Port C of instance reset_reg(FD) in module top
Port C of instance \count_reg[51] (FD) in module top
Port C of instance \count_reg[50] (FD) in module top
Port C of instance \count_reg[49] (FD) in module top
Port C of instance \count_reg[48] (FD) in module top
Port C of instance \count_reg[47] (FD) in module top
Port C of instance \count_reg[46] (FD) in module top
Port C of instance \count_reg[45] (FD) in module top
Port C of instance \count_reg[44] (FD) in module top
Port C of instance \count_reg[43] (FD) in module top
Port C of instance \count_reg[42] (FD) in module top
Port C of instance \count_reg[41] (FD) in module top
Port C of instance \count_reg[40] (FD) in module top
Port C of instance \count_reg[39] (FD) in module top
Port C of instance \count_reg[38] (FD) in module top
Port C of instance \count_reg[37] (FD) in module top
Port C of instance \count_reg[36] (FD) in module top
Port C of instance \count_reg[35] (FD) in module top
Port C of instance \count_reg[34] (FD) in module top
Port C of instance \count_reg[33] (FD) in module top
Port C of instance \count_reg[32] (FD) in module top
Port C of instance \count_reg[31] (FD) in module top
Port C of instance \count_reg[30] (FD) in module top
Port C of instance \count_reg[29] (FD) in module top
Port C of instance \count_reg[28] (FD) in module top
Port C of instance \count_reg[27] (FD) in module top
Port C of instance \count_reg[26] (FD) in module top
Port C of instance \count_reg[25] (FD) in module top
Port C of instance \count_reg[24] (FD) in module top
Port C of instance \count_reg[23] (FD) in module top
Port C of instance \count_reg[22] (FD) in module top
Port C of instance \count_reg[21] (FD) in module top
Port C of instance \count_reg[20] (FD) in module top
Port C of instance \count_reg[19] (FD) in module top
Port C of instance \count_reg[18] (FD) in module top
Port C of instance \count_reg[17] (FD) in module top
Port C of instance \count_reg[16] (FD) in module top
Port C of instance \count_reg[15] (FD) in module top
Port C of instance \count_reg[14] (FD) in module top
Port C of instance \count_reg[13] (FD) in module top
Port C of instance \count_reg[12] (FD) in module top
Port C of instance \count_reg[11] (FD) in module top
Port C of instance \count_reg[10] (FD) in module top
Port C of instance \count_reg[9] (FD) in module top
Port C of instance \count_reg[8] (FD) in module top
Port C of instance \count_reg[7] (FD) in module top
Port C of instance \count_reg[6] (FD) in module top
Port C of instance \count_reg[5] (FD) in module top
Port C of instance \count_reg[4] (FD) in module top
Port C of instance \count_reg[3] (FD) in module top
Port C of instance \count_reg[2] (FD) in module top
Port C of instance \count_reg[1] (FD) in module top
Port C of instance \count_reg[0] (FD) in module top
It looks like there is a "Input buffer" inside design_1_wrapper.
Maybe Vivado insert that buffer when you build "design_1_wrapper".
Let remove it in "design_1_buffer" and try to synthesis again. There will be 1 input buffer for both microblaze and count register clock pin.
so, how can I remove it? I tried to remove it by these command "(* io_buffer_type = "NONE" *)" ,... but it failed again.
I found the solution.
I had made a very very simple mistake.
I had used the wrong clock signal. I can't use input clock when I have digital clock manager in my circuit.
thank you all.
Just in case you dont want to have the buffer, let skip the auto insertion from Vivado when building the design_1_wrapper design. Or, you can manually remove the buffer and just connect its input output.
The input buffer will be inserted between IO and input clock pin later on Vivado.
