how to Install cadence IC610 with Fedora-8-Live-FEL-i686 ?
QuanBao
procedure for installing ic610 cadence tools
i ran setup.sh and got the message follow the attachment .What's else i can do ?
I'm newbie with Linux .
Thanks in advance. Any help are welcome .
omara007
Cairo/Egypt
cadence ic 610 tools
I don't believe that you can install any tool on a live-CD version of linux ..
    QuanBao
QuanBao
cadence ic610
what's the best linux os to use with cadence IC610 ?
omara007
Cairo/Egypt
install cadence
There are many linux distros that can be used with EDA tools .. like RHEL .. CentOS .. Fedora .. etc.
The best thing to do first, is to go to cadence website and see their recommended linux distros.
QuanBao
how to install cadence
i changed to Ubuntu 7.10 ,it's work .But when installing it ask for CD#2 ,i put cd#2 into tray .I don't know why it's couldn't continuing install .System doesn't mount that CD to install .
Any ideas ?
omara007
Cairo/Egypt
install ic610 procedure
sometimes the CDs get corrupted .. try to have another copy of CD2.
QuanBao
fedora uncompress cadence
unlucky i got no source to have that .
none34
Newbie level 5
ic610 fedora
the file in CD usually zipped or compressed.
simply unzip and uncompress all of the file.
set proper environment,it will work.
quaternion
Full Member level 4
Cairo , Egypt
how to install local cadence
My experience with installing IC5141 is :
to create a directory with the name of the component(for example Base, Hotfix , Assurabase,.. )
,and extract all the CDs of each component within its directory forexample: Base (directo.) contains 4 directories named CD1 , CD2 , CD3 , CD4 (each contains the extraction of each CD) and then when you are asked for the installation path give it the path of the first CD and it will see the others -this appears in a message after path selection and before install- and mount automatically without asking you , some times when I did something wrong during the install such a message of mounting CD2 appear which in most case means that I shall start to install from the first again.
hock
Advanced Member level 2
India
cadence ic610 install
look at the installation procedure i have described here.
hock
Clunixchit
Member level 1
how to install cadence ic 610 linux setup.sh
Thus he means you have to install FEL first, then install cadence.
