Haward Zhu
Newbie level 2
hi guys, i'm design a clock generator with a 25MHz crystalloid and a 200MHz signal output. i chose the classical pll configuration consisting of PFD CP LF VCO and divider.
i'm in trouble on how to eliminate the static phase error which should not exit in theory. i have no idea if it causes the ripple of the output voltage of CP, and it400ps Jcc.
and i have a question about the pnoise simulation. what does "output frequency sweep range" mean? i chose 10K-800M for the 200MHz output, and i got 400ps Jcc. if i reduce the range(e.g. 150M-300M), results get better. is that valid?how much sweep range i need at least?
thanks!
thanks!
