kumuking
Newbie level 3
Recently I've almost finished a assignment.
But when I think I was done, problem came to me.
When I simulate the top level port map vhdl codes, nothing worked. I have attached a picture which is the simulation.
I think my codes are right. And I also set a configuration to relate the binding information between component and library.
I also attached 1 zip file which including 4 vhdl codes.
The assi8.vhd is the top level port map codes.
The assi8a.vhd is the testbench codes.
The assi8b.vhd is the module1 codes.
The assi8c.vhd is the module2 codes.
And I've googled a lot about the top level port map, but I found nothing to solve my problem.
Could you tell me how to solve the problem?
Thank you very much.
View attachment VHDL.zip
