-- The output data: 8 bit - this is the UART receiver
-- Data is only valid during the time the STB is high
-- Acknowledge the data with a pulse on ACK, which is confirmed by
-- revoking STB.
-- When the following start bit is received the data becomes
-- invalid and the STB is revoked. So take care about fetching the
-- data early enough, or install your own FIFO buffer
DATA_STREAM_OUT : out std_logic_vector(7 downto 0);
DATA_STREAM_OUT_STB : out std_logic;
DATA_STREAM_OUT_ACK : in std_logic;
TX : out std_logic;
