how to implement code in virtex5 using BRAM and FIFO core generator
holambe
Newbie level 3
Newbie level 3
I have code for cryptanalysis of AES(128 bit ) want to implement it on virtex5 board using core generator...
I generate BRAM and FIFO using core generator, and read data from text file as input for code also write output to text file....
output is seen in simulation result but write file shows 0000000....00000 value not the output value seen in simulation result...
help me
Thankx
core generated BRAM code and core generated FIFO is below
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
-- synthesis translate_off
LIBRARY XilinxCoreLib;
-- synthesis translate_on
ENTITY crypt_ram IS
  PORT (
    clka : IN STD_LOGIC;
    wea : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
    addra : IN STD_LOGIC_VECTOR(127 DOWNTO 0);
    dina : IN STD_LOGIC_VECTOR(127 DOWNTO 0);
    douta : OUT STD_LOGIC_VECTOR(127 DOWNTO 0)
END crypt_ram;
ARCHITECTURE crypt_ram_a OF crypt_ram IS
COMPONENT wrapped_crypt_ram
  PORT (
END COMPONENT;
-- Configuration specification
  FOR ALL : wrapped_crypt_ram USE ENTITY XilinxCoreLib.blk_mem_gen_v7_1(behavioral)
    GENERIC MAP (
      c_addra_width => 14,
      c_addrb_width => 14,
      c_algorithm => 1,
      c_axi_id_width => 4,
      c_axi_slave_type => 0,
      c_axi_type => 1,
      c_byte_size => 9,
      c_common_clk => 0,
      c_default_data => "0",
      c_disable_warn_bhv_coll => 0,
      c_disable_warn_bhv_range => 0,
      c_enable_32bit_address => 0,
      c_family => "virtex5",
      c_has_axi_id => 0,
      c_has_ena => 0,
      c_has_enb => 0,
      c_has_injecterr => 0,
      c_has_mem_output_regs_a => 0,
      c_has_mem_output_regs_b => 0,
      c_has_mux_output_regs_a => 1,
      c_has_mux_output_regs_b => 0,
      c_has_regcea => 0,
      c_has_regceb => 0,
      c_has_rsta => 0,
      c_has_rstb => 0,
      c_has_softecc_input_regs_a => 0,
      c_has_softecc_output_regs_b => 0,
      c_init_file_name => "no_coe_file_loaded",
      c_inita_val => "0",
      c_initb_val => "0",
      c_interface_type => 0,
      c_load_init_file => 0,
      c_mem_type => 0,
      c_mux_pipeline_stages => 3,
      c_prim_type => 1,
      c_read_depth_a => 13256,
      c_read_depth_b => 13256,
      c_read_width_a => 128,
      c_read_width_b => 128,
      c_rst_priority_a => "CE",
      c_rst_priority_b => "CE",
      c_rst_type => "SYNC",
      c_rstram_a => 0,
      c_rstram_b => 0,
      c_sim_collision_check => "ALL",
      c_use_byte_wea => 0,
      c_use_byte_web => 0,
      c_use_default_data => 0,
      c_use_ecc => 0,
      c_use_softecc => 0,
      c_wea_width => 1,
      c_web_width => 1,
      c_write_depth_a => 13256,
      c_write_depth_b => 13256,
      c_write_mode_a => "WRITE_FIRST",
      c_write_mode_b => "WRITE_FIRST",
      c_write_width_a => 128,
      c_write_width_b => 128,
      c_xdevicefamily => "virtex5"
BEGIN
U0 : wrapped_crypt_ram
  PORT MAP (
    clka => clk,
    wea => wea,
    addra => addra,
    dina => cipher,
    douta => KEY_OUTMAIN
END crypt_ram_a;
LIBRARY ieee;
ENTITY crypt_fifo IS
  PORT (
    clk : IN STD_LOGIC;
    rst : IN STD_LOGIC;
    din : IN STD_LOGIC_VECTOR(127 DOWNTO 0);
    wr_en : IN STD_LOGIC;
    rd_en : IN STD_LOGIC;
    dout : OUT STD_LOGIC_VECTOR(127 DOWNTO 0);
    full : OUT STD_LOGIC;
overflow : OUT STD_LOGIC;
almost_full: OUT STD_LOGIC;
    empty : OUT STD_LOGIC
END crypt_fifo;
ARCHITECTURE crypt_fifo_a OF crypt_fifo IS
COMPONENT wrapped_crypt_fifo
  PORT (
    clk : IN STD_LOGIC;
    rst : IN STD_LOGIC;
END COMPONENT;
  FOR ALL : wrapped_crypt_fifo USE ENTITY XilinxCoreLib.fifo_generator_v9_1(behavioral)
    GENERIC MAP (
      c_add_ngc_constraint => 0,
      c_application_type_axis => 0,
      c_application_type_rach => 0,
      c_application_type_rdch => 0,
      c_application_type_wach => 0,
      c_application_type_wdch => 0,
      c_application_type_wrch => 0,
      c_axi_addr_width => 32,
      c_axi_aruser_width => 1,
      c_axi_awuser_width => 1,
      c_axi_buser_width => 1,
      c_axi_data_width => 64,
      c_axi_ruser_width => 1,
      c_axi_type => 0,
      c_axi_wuser_width => 1,
      c_axis_tdata_width => 64,
      c_axis_tdest_width => 4,
      c_axis_tid_width => 8,
      c_axis_tkeep_width => 4,
      c_axis_tstrb_width => 4,
      c_axis_tuser_width => 4,
      c_axis_type => 0,
      c_common_clock => 1,
      c_count_type => 0,
      c_data_count_width => 12,
      c_default_value => "BlankString",
      c_din_width => 128,
      c_din_width_axis => 1,
      c_din_width_rach => 32,
      c_din_width_rdch => 64,
      c_din_width_wach => 32,
      c_din_width_wdch => 64,
      c_din_width_wrch => 2,
      c_dout_rst_val => "0",
      c_dout_width => 128,
      c_enable_rlocs => 0,
      c_enable_rst_sync => 1,
      c_error_injection_type => 0,
      c_error_injection_type_axis => 0,
      c_error_injection_type_rach => 0,
      c_error_injection_type_rdch => 0,
      c_error_injection_type_wach => 0,
      c_error_injection_type_wdch => 0,
      c_error_injection_type_wrch => 0,
      c_full_flags_rst_val => 1,
      c_has_almost_empty => 0,
      c_has_almost_full => 0,
      c_has_axi_aruser => 0,
      c_has_axi_awuser => 0,
      c_has_axi_buser => 0,
      c_has_axi_rd_channel => 0,
      c_has_axi_ruser => 0,
      c_has_axi_wr_channel => 0,
      c_has_axi_wuser => 0,
      c_has_axis_tdata => 0,
      c_has_axis_tdest => 0,
      c_has_axis_tid => 0,
      c_has_axis_tkeep => 0,
      c_has_axis_tlast => 0,
      c_has_axis_tready => 1,
      c_has_axis_tstrb => 0,
      c_has_axis_tuser => 0,
      c_has_backup => 0,
      c_has_data_count => 0,
      c_has_data_counts_axis => 0,
      c_has_data_counts_rach => 0,
      c_has_data_counts_rdch => 0,
      c_has_data_counts_wach => 0,
      c_has_data_counts_wdch => 0,
      c_has_data_counts_wrch => 0,
      c_has_int_clk => 0,
      c_has_master_ce => 0,
      c_has_meminit_file => 0,
      c_has_overflow => 0,
      c_has_prog_flags_axis => 0,
      c_has_prog_flags_rach => 0,
      c_has_prog_flags_rdch => 0,
      c_has_prog_flags_wach => 0,
      c_has_prog_flags_wdch => 0,
      c_has_prog_flags_wrch => 0,
      c_has_rd_data_count => 0,
      c_has_rd_rst => 0,
      c_has_rst => 1,
      c_has_slave_ce => 0,
      c_has_srst => 0,
      c_has_underflow => 0,
      c_has_valid => 0,
      c_has_wr_ack => 0,
      c_has_wr_data_count => 0,
      c_has_wr_rst => 0,
      c_implementation_type => 0,
      c_implementation_type_axis => 1,
      c_implementation_type_rach => 1,
      c_implementation_type_rdch => 1,
      c_implementation_type_wach => 1,
      c_implementation_type_wdch => 1,
      c_implementation_type_wrch => 1,
      c_init_wr_pntr_val => 0,
      c_memory_type => 1,
      c_mif_file_name => "BlankString",
      c_msgon_val => 1,
      c_optimization_mode => 0,
      c_overflow_low => 0,
      c_preload_latency => 1,
      c_preload_regs => 0,
      c_prim_fifo_type => "4kx9",
      c_prog_empty_thresh_assert_val => 2,
      c_prog_empty_thresh_assert_val_axis => 1022,
      c_prog_empty_thresh_assert_val_rach => 1022,
      c_prog_empty_thresh_assert_val_rdch => 1022,
      c_prog_empty_thresh_assert_val_wach => 1022,
      c_prog_empty_thresh_assert_val_wdch => 1022,
      c_prog_empty_thresh_assert_val_wrch => 1022,
      c_prog_empty_thresh_negate_val => 3,
      c_prog_empty_type => 0,
      c_prog_empty_type_axis => 0,
      c_prog_empty_type_rach => 0,
      c_prog_empty_type_rdch => 0,
      c_prog_empty_type_wach => 0,
      c_prog_empty_type_wdch => 0,
      c_prog_empty_type_wrch => 0,
      c_prog_full_thresh_assert_val => 4094,
      c_prog_full_thresh_assert_val_axis => 1023,
      c_prog_full_thresh_assert_val_rach => 1023,
      c_prog_full_thresh_assert_val_rdch => 1023,
      c_prog_full_thresh_assert_val_wach => 1023,
      c_prog_full_thresh_assert_val_wdch => 1023,
      c_prog_full_thresh_assert_val_wrch => 1023,
      c_prog_full_thresh_negate_val => 4093,
      c_prog_full_type => 0,
      c_prog_full_type_axis => 0,
      c_prog_full_type_rach => 0,
      c_prog_full_type_rdch => 0,
      c_prog_full_type_wach => 0,
      c_prog_full_type_wdch => 0,
      c_prog_full_type_wrch => 0,
      c_rach_type => 0,
      c_rd_data_count_width => 12,
      c_rd_depth => 4096,
      c_rd_freq => 1,
      c_rd_pntr_width =>12,
      c_rdch_type => 0,
      c_reg_slice_mode_axis => 0,
      c_reg_slice_mode_rach => 0,
      c_reg_slice_mode_rdch => 0,
      c_reg_slice_mode_wach => 0,
      c_reg_slice_mode_wdch => 0,
      c_reg_slice_mode_wrch => 0,
      c_synchronizer_stage => 2,
      c_underflow_low => 0,
      c_use_common_overflow => 0,
      c_use_common_underflow => 0,
      c_use_default_settings => 0,
      c_use_dout_rst => 1,
      c_use_ecc => 0,
      c_use_ecc_axis => 0,
      c_use_ecc_rach => 0,
      c_use_ecc_rdch => 0,
      c_use_ecc_wach => 0,
      c_use_ecc_wdch => 0,
      c_use_ecc_wrch => 0,
      c_use_embedded_reg => 0,
      c_use_fifo16_flags => 0,
      c_use_fwft_data_count => 0,
      c_valid_low => 0,
      c_wach_type => 0,
      c_wdch_type => 0,
      c_wr_ack_low => 0,
      c_wr_data_count_width =>12,
      c_wr_depth => 4096,
      c_wr_depth_axis => 1024,
      c_wr_depth_rach => 16,
      c_wr_depth_rdch => 1024,
      c_wr_depth_wach => 16,
      c_wr_depth_wdch => 1024,
      c_wr_depth_wrch => 16,
      c_wr_freq => 1,
      c_wr_pntr_width =>12,
      c_wr_pntr_width_axis => 10,
      c_wr_pntr_width_rach => 4,
      c_wr_pntr_width_rdch => 10,
      c_wr_pntr_width_wach => 4,
      c_wr_pntr_width_wdch => 10,
      c_wr_pntr_width_wrch => 4,
      c_wr_response_latency => 1,
      c_wrch_type => 0
BEGIN
U0 : wrapped_crypt_fifo
  PORT MAP (
    clk => clk,
    rst => rst,
    din => dina,
    wr_en => wr_en,
    rd_en => rd_en,
    dout => douta,
    full => full,
    overflow => overflow,
almost_full=> almost_full,
    empty => empty
END crypt_fifo_a;
How is this posted code supposed to tell us anything. From your own description it's a problem with the testbench you wrote that isn't writing the values out to a file. Post the TESTBENCH not the cores.
What is with the people that post on this forum, don't they understand that none of us are psychics and we don't own crystal balls (at least I don't).
thank for reply, now below is my testbench code
read value as ip is
"000102030405060708090a0b0c0d0e0f"
output key is
"0000000000000000000000000000012b"
which shown in simulation waveform but not write.
in simulation firstly set rest to 1 and then to 0.
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
LIBRARY ieee;
use IEEE.std_logic_textio.all;
use std.textio.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY testbench_crypt IS
END testbench_crypt;
ARCHITECTURE behavior OF testbench_crypt IS
    -- Component Declaration for the Unit Under Test (UUT)
    COMPONENT new_top
    PORT(
         clk : IN  std_logic;
         reset : IN  std_logic;
         cipher : IN  std_logic_vector(127 downto 0);
         plaintext_in : IN  std_logic_vector(127 downto 0);
         in_cnt : IN  std_logic_vector(127 downto 0);
         KEY_OUTMAIN : OUT  std_logic_vector(127 downto 0));
    END COMPONENT;
   --Inputs
   signal clk : std_logic := '0';
   signal reset : std_logic := '0';
   signal cipher : std_logic_vector(127 downto 0) := (others => '0');
   signal plaintext_in : std_logic_vector(127 downto 0) := x"ff43194f7363576af7186dfea68175da";
   signal in_cnt : std_logic_vector(127 downto 0):=x"00000000000000000000000000000000";
    signal ip,keyoutmain : std_logic_vector(127 downto 0);
    --Outputs
   signal KEY_OUTMAIN : std_logic_vector(127 downto 0);
   signal out_sig : std_logic;
   -- Clock period definitions
   constant clk_period : time := 10 ns;
BEGIN
    -- Instantiate the Unit Under Test (UUT)
   uut: new_top PORT MAP (
          clk => clk,
          reset => reset,
          cipher => ip,
          plaintext_in => plaintext_in,
          in_cnt => in_cnt,
          KEY_OUTMAIN => keyoutmain);
   -- Clock process definitions
   clk_process :process
   begin
        clk <= '0';
        wait for clk_period/2;
        clk <= '1';
   end process;
   -- Stimulus process
   stim_proc: process
        file infile : TEXT open read_mode is "E:\holambe\ip.txt";
file outfile : TEXT open write_mode is "E:\holambe\keyoutmain.txt";
variable ip1,op1 : std_logic_vector (127 downto 0);
variable buf : line;
begin
while not (endfile(infile)) loop
readline(infile,buf);
hread (buf,ip1);
ip<=ip1;
wait until falling_edge(clk);
op1:=keyoutmain;
hwrite(buf,op1);
writeline(outfile,buf);
end loop;
wait;
end process  stim_proc;
end ;
I was going to look this over some more tonight and over the weekend, but with your incessant posting about the same subject (violating the forum rules), I've decided to spend time elsewhere.
Good luck fixing your problem.
