How to hide my PC from network administrator
asimraufawan
Member level 2
hide from network administrator
Hi all,
how i will protect my PC from network administrator
is there any way or trick to do that.
how to hide from network administrator
Unplug the network cable :)
hide my pc
hi
go to the sharing folders
and cancel all sharing folders
other thing
put asecret word when you use the network
that all
\and as my freind say
you can un polg the net work cable
hide pc from network
Ok
install any firewall like "zonealarm" any cancel ping replay so any one can't ping you pc
Sokrat
hide pc on network
Personal firewall is the best idea. Zonealram is one of the best. But there is a variety of other firewalls. Nowadays firewall is as necessary as anti virus.
hide my pc from network
Well as you are on the same network other then unplugging your machine there is no other way. Even with a personal firewall when you'ld try to access the Network (probably a LAN) your admin will see you.
hide form network administrator
You simply can't. The network admin can access your PC every time they want to if you are on a domain system. You can try workgroup networking to avoid external intrusion.
But still, Network admin is called network admin BECAUSE he/she can access your PC, otherwise there is no point in being an admin, :)
how to hide pc from network
If he install Personal firewall the administrator can't access OR bing his pc :D
Sokrat
hide pc
Sokrat
But if he has an Admin he most likely can't install software and when he trues he'll be busted.
Added after 1 minutes:
Just a reminder there is no anonymity in the Internet.
hide my pc on network
Sokrat
Yes you are right .. amm but I was saw Video " but in Arabic language " how you can access winXP and install your programs without administrator password ?
how to hide my pc from network
personal firewall and cancel all the shared folders, by this you ll be secured
how to hide my pc
Put a blanket on your PC
Your PC will be hidden from your network Adm:D:D:D
