orcad_help_needed
In OrCAD you can create Layout Netlist file for different Layout Tool.
First create a small schematic with resistor or diode.
If you are using OrCAD Layout itself, then create the OrCAD Netlist.
There are few ways to create MNL file.
From OrCAD Layout or from OrCAD Layout Plus create a new Layout.
Select the default template and the created MNL File.
While importing, select Radial for the resistors and select the equivalent PADs.
When the import is finished without errors, it will place in the Layout screen.
Move the device footprints as per the design.
Go for autoroute.
It will create the routing.
Then print.
