[SOLVED] How to give two different values to a reg in testbench?
krishna2728
Member level 5
bengaluru,India
Hii Frnds,
i have to change a reg value ,but its taking the second value evry time and ignoring the first one as i have to check first value then the reg value must change as in the example
#25 REQA_WUPA_flag=1'b1;pcd_command=128'h26;
#100 ACCL_flag=1'b1;pcd_command=128'h2093;
as shown pcd_command value must be first 26 then when the accl_flag is high then it must be 2093
thank you in advance
You should pull up the waveform viewer to see whats happening at #25? Which means check the REQA flag and the value of pcd_command.
This should help you.
