how to give cosine wave in pspice
vetriece86@gmail.com
Junior Member level 2
1. Is it possible to give directly a cosine waveform in pspice.
2. Then how to give cosine waveform in pspice other than using integrator circuit.
Thanks in advance
just use free LTspice (free download) and put a voltage source on there........add a ground into the circuit...and click on the voltage source and set up as sinusoidal source, and delay it by 90 degrees and you've got your cosine.
Of course, the same works in PSpice .
Reactions: treez
    T
