adm1
Junior Member level 1
hi guys
i want to knw how we can give external trigger to a pic18 circuit board.
i am using mikro c for code and proteus simulation. if i give a trigger on one of the pins, it should glow the led's connected to some other port.
the program works fine with mikro c and proteus.. but when i test it on hardware the trigger goes to the microcontroller, but the function it has to perform is not happening
are there any special command in mikroc required for external trigger interfacing ?
