Oh, did you get the H-plane and E-plane in the far field on HFSS?How could you do that? Is it as follow:Choose
Creat report»far filed » radiation pattern»rE»rEtotal» dB? But that just means rE, not E. I want to plot the E-plane and H-plane, while I cannot find E just rE, so could tell me the step to show the E-plane and H-plane?
if you want to plot E you will have to specify r.You can create a near field sphere setup and specify a large radius in order to see the far fields.Then by choosing fields or near fields in results you will be able to plot E.I hope this helps!!!.
