yashwanth1885
Newbie level 6
Hello everyone,
I am trying to find the current(Amps) along the vias in the seivenpiper structure using HFSS 10.
Structure: I am simulating a unit cell with patch on a grounded dielectric slab which is connected to ground by vias. The excitation I am using is plane wave with oblique incidence and TM polarization. For TM polarization oblique incidence the E-field will interact with the vias and induces current in it. The current is supposed to be uniform(confirmed by CST).
So, in the first method what I did is, I defined a polyline along the surface of the vias and in the post processing, I calculated mag_jvol and complx_Jvol over this polyline, but the current density is not unifrom.
Second method: I defined a circular polyline and calculated integral(H.dl).
then repeated this for various circles along the via at various points and calculated the current. Even then the current is not unifrom.
Can anyone please tell me, what am I doing wrong? When I calculated the reflected phase, its same as CST(done by some one).
thank you.
Yash
thank you.
Yash
