How to generate solder mask layer in Eagle ?
Alwaleed2
Member level 3
Member level 3
eagle solder mask
I want to generate solder mask layer in Eagle 4.15 to print it , How
eagle soldermask
If your question is how to get one for a board you made, try using the the tstop layer.
Printing is an exercise left to the student...
solder mask eagle
But i want to know how to print it from Eagle
A.Abbas
solder mask layer
ok. I guess you missed the part in the tutorial about printing. press the display button and clear all visible layers except tstop (or bstop for the bottom). then file/print.
eagle solder mask layer
I know that , but I want to generat the solder mask layer in eagle with out using any external tool to invert colors
LaTeX Commands Quick-Menu:
