how to generate random numbers using C-langugae?
Delta11
Junior Member level 3
Random number generation
Guys...... I need to get an idea how to generate random numbers using C-langugae? Would it be possible to implement such a thing efficiently using moderate microcontrollers like PIC or AVR series!
Hi Delta11,
Look for "linear congruential method".
This is one of the most common and simple methods for generating random numbers with uniform distribution.
Regards
Z
    Delta11
take an array and enter no's in it
Added after 1 minutes:
or use pointers and give address with increment of 2.
Re: Random number generation
Use the following code for a linear congruential generater. It uses a 32-bit global unsigned integer. It must be 32 bits! For the PIC C18 compiler you can use unsigned long. You can set the seed with setSeed(seed) and get a random number with rand().
unsigned long x;
void setSeed(unsigned long seed) {
  x=seed;
unsigned long rand() {
  x = 1103515245 * x + 12345;
  return x & 0x3FFFFFFF;
Slorn
dwengo... gets you started with microcontrollers!
OK.
Take into account that the above code generates uniformly distributed numbers in the range [0, 0x3FFF] (14 bits).
Regards
Z
Hi zorro
That was a mistake. It should have been 0x3FFFFFFF (30-bits). I changed the code above. The code implements the gcc random generator.
If you want a smaller range just take as little bits as you need. E.g. if you need 8 bit random numbers use 0x000000FF.
Slorn
Hi
Use your A/D converter as a source for producing random number(seed) by connecting one of the A/D input via a resistor to GND and read the result without filter or summing
All the best
Bobi
The microcontroller specialist
