How to generate a HEX file - Microchip serial EEPROM
jprg
Junior Member level 1
I want to use PICkit 2 to program an external EEPROM out of circuit (Microchip 25LC1024).
PICkit 2 Readme file describes electrical connections between the two.
What I can't figure out is how to generate a HEX file so I can load it into the EEPROM. MPLAB IDE has all support for the chip showing in red (not available).
Any advice?
Thanks.
Data can be a pure binary file or a .wav file, depending on application.
Could you point me to some utilities that can generate a hex file that PICkit 2 would understand?
Thanks.
PICkit is surely understanding standard Intel hex format, that's used for all Microchip flash files. Google for binhex converter.
