How to generate 64 QAM in Matlab 6.5
venkateshkumar
Newbie level 6
HI
any one of u know how to generate 64 qam in matlab 6.5
please help me
thanks in advance
regards
venkatesh
64qam matlab
hi ,
U need separate function to generate 64-QAM or built in function is enough .
Built in function is
data=randint(1,100,6); ----> generates 100 symbols which are in range of 0 to 63
mod_data=qammod(data,6);
If you want to check the constellation plot give following command
scatterplot(mod_data);
Any mistakes correct me.
Regards,
Goud
Reactions: ranjay
    ranjay
qam matlab code
there is any error showing on the second line of urs ,and not working .
i dnt know how to correct it because i also want to know how 64 qam is made
64 qam matlab file
hi friend,
see this chapter from the help of matlab 6.5 in the attachment area. Also you can find more examples on the mathwork web site, just do search within it for your keyword.
Another way for you, you can do search in the matlab help on your computer for digital modulation as a keyword or just modulation.
Regards
matlab qam
is it OK?
64 qam matlab code
hi
any one of u know how to simulate LNB signal in matlab.
please help me
thanks in advance
Regards
alaa17
Re: 64 QAM MATLAB CODE
i attached code for 64 qam in matlab try it
close all;
clear all;
m=64;
i=1;
d1=input('enter the i/p sequence=');
n=length(d1);
if n%6==1
d1(n+1:n+5)=0;
l=n+5;
elseif n%6==2
d1(n+1:n+4)=0;
l=n+4;
elseif n%6==3
d1(n+1:n+3)=0;
l=n+3;
elseif n%6==4
d1(n+1:n+2)=0;
l=n+2;
elseif n%6==5
d1(n+1)=0;
l=n+1;
else
l=n;
end;
%d2(1:1:6)=0;
d4(1:(l/6))=0;
for j=1:(l/6)
d2=[d1(i+5) d1(i+4) d1(i+3) d1(i+2) d1(i+1) d1(i)];
d3=binvec2dec(d2);
d4(j)=d3;
i=i+6;
end;
y3=qammod(d4,m);
scatterplot(y3);
for j=1Sadl/6)
d4(j)=d3;
error on this line
these two lines how can i debug these errors??
i need 16 qam code
