How to generate 2 TDM PAM signals in Matlab ?
squirrel
Member level 3
Member level 3
matlab code help needed
HI
i need to know how can i generate two channel time division multiplexing (TDM) of pulse amplitude modulated (PAM) signal and detect the same TDM PAM signal using a synchronizer in MATLAB.
please help. it's urgent.
thanks
mm
Kind of big thing, it is not clear what do you mean by two channel, I am assuming you have 2 users, then if you have to share the channel between 2 users, you just assign equal time for both of them, in each time you apply normal PAM, that is it, if the users have different loads, then things are more complicated and you need to search for algorithms.
good luck
Sal
Re: matlab code help needed
HI
thanks for ur reply. yes i've two users. suppose i can generate the tdm somehow. but how to detect them using matlab. i'm very much confused.
thanks
bye
