How to force node voltage (analog) in AMS simulation.
findsriharsha
Member level 3
California US
Hello,
I need to set the node voltage to a particular analog value throughout my AMS sim. Does anyone know how to do that?
I have done the same thing using "force" statement for digital signal in AMS and it had worked. I tried this for analog signal, it didnt work. Please help!
I dont think .NODESET or .IC will work as they are used to just set the initial condition for convergence. Suggest me if I am wrong..
Thanks in advance..
You can just add a voltage source to the node. As a SPICE line, it would look like this:
VFORCE NodeName 0 5
This line forces node "NodeName" to 5V above Ground, by adding a voltage source called "VFORCE"
Hope this helps.
Hi Zeker,
Thanks for the quick response. I am running this AMS sim from a snapshot. Can I use this VFORCE command in the AMS script?
Please let me know if my question does not make any sense, I will try rephrasing it
Thanks!
I'm not sure how AMS works, but it's pretty standard SPICE notation. If you can enter other standard SPICE commands like .NODESET and .IC, I would imagine you should be able to enter this line too.
I tried VFORCE, it does not work in cadence environment. Does anyone else have any suggestion?
Okay, perhaps that's just standard syntax for LTspice. According to **broken link removed**, the netlist uses this sort of syntax:
V4 (NodeName GND) vsource dc=5 type=dc
Let me know if this works for you.
