Hello,
I don't know if this is the right place to ask, but maybe there is someone with the skills.
We have a
gas furnace at home, for the central heating of the house and for the hot water of the taps.
The model of this furnace is
Junkers Cerastar ZWR 18-5 KE 23 from Bosch.
I live in Germany and the instruction manual is in German only.
The problem:
The heater works perfectly and there is hot water and heating in all the rooms,
but the pressure of the pipeline for the house heating is under the recommended 1 Bar.
See the attached picture.
How to fix it:
In the manual it says: "If the pressure is too low, you need to open a valve, to let water in to the pipelines, while keeping an eye on the pressure gauge until it reads again 1 Bar. Then you close the valve." But I cannot find the said valve.
The question:
Do you know how to refill this one?
Where is the valve that I should turn on?
