LvW
Advanced Member level 6
Hello,
Up to now, this thread was visited by 175 forum members – and I assume some (if not most of them) are not yet very well experienced in analog electronics. Therefore, I think it could be helpful to comment and to correct some statements and formulas as contained in the document <http://www.johnhearfield.com/RC/RC4.htm< referenced by BradtheRad.
General comment: The author always speaks about „break frequencies“ without any definition. Obviously, for a first order RC circuit this frequency is identical to the 3dB frequency (pole frequency). But by mistake he also applies this wording to a second order RC circuit. In fact, both frequencies (called w1 and w2, resp.) are complex frequencies which determine the pole location in the s-plane (in this case: two poles on the neg.real axis).
In the chapter following the BODE diagram both „break frequencies“ are calculated. Although for the selected parts values the results may be approximately correct, the calculation assumes two decoupled RC sections, which obviously is not the case.
*Quotation: And since I can clearly see two separate and predictable break frequencies, why won't the expression for G factorise into two separate break-frequency terms? What's going on?
Of course, the expression for G can be factorized in two terms – because (as mentioned above) in reality the „break frequencies“ are the „pole frequencies“ wp. And each second order denominator can be split into two expressions like (1+jw/wp).
*Quotation: ...increase the value of capacitor D from 1nF to 50nF - so that the two break frequencies become (supposedly) the same.
I don’t know how the author came to this (false) conclusion. Of course, these frequencies (whatever their name may be) are NOT the same. For the selected values we have w1=-585.8 1/s and w2=-3414.2 17s.
*Quotation: The break frequencies ω1 and ω2 can be written . . . . so that ω1ω2 = ω0
Here the author, indirectly, confirms my interpretation that the „break frequencies“ are identical to the pole locations. At this point it is to be mentioned that the given formula G=f(Q,wo) is derived for a 2nd order circuit with a complex pole pair. Here, wo is the pole frequency (magnitudes of both pole vectors); for Q=0.5 both conjugate-complex poles combine to a double pole on the neg. real axis and split again into two real poles for Q<0.5 (as in our case).
*Quotation: In fact, it's not hard to prove that the maximum value Q can have in this circuit is 0.353, which happens when D=50nF. Higher values of Q can be achieved by active filters - that is, by circuits which include op-amps.
From system theory it is known that the maximum possible value for a passive second-order RC circuit is Qmax=0.4999 (Qmax=0.5 for decoupled sections). Q=0.353 applies to the selected values only, but it is not the possible maximum.
__________________________________-
Sorry for the lengthy comment. Perhaps it helps to better understand passive 2nd order low pass filters.
LvW
LvW
