How to find number of registers in a design?
kirangu
Junior Member level 2
This is the an interview question. Please help me finding answer for it.
qual_ti
Member level 1
in DC, we can get the no of registers in the design.
we can use command like report_all_reg in DC shell.
It will give the no of registers in the design.
correct me if I am wrong..
kirangu
Even i dont know the exact answer for it.... lets say we have a netlist... before doing pd.. Can we find number of flops, instances in the design?
dcreddy1980
Full Member level 5
Munich, Germany
If You are given a netlist and you have to find number of FLOPS from i.
Thing is if you know what kind of technology it is and what FF primitives exist in that technology like : FD,FDCE,FD and so on
If you get the list of FLOP primitive names, we can create a perl script to get the count.
ADITYAVARDHAN
Junior Member level 1
If you compile the design in the compilation report we get the number of registers and the gates used in FPGA's.If I am wrong please correct me.
GI
Member level 2
Istanbul/Turkiye
Hi Kirangu,
There may be a couple of ways to report number of flops in a design;
1 - Simplest may be to do "grep" on the netlist with specific filtering or regular expression (e.g. reference cell name or pattern)
2 - Writing you tcl/perl script to count it (using regular experssion or giving whole set of register on that technology and checking each line of the verilog)
3 - Using the synthesis, physical design or STA tool's native commands (as stated above "report_all_reg", etc...)
I hope it helps,
Gokhan
anantha_09
Member level 4
synopsys DC can report num of regs in design
chiplogic
Junior Member level 3
chennai
how about [all_registers] and count the number using some script?
kumar_eee
Advanced Member level 3
Bangalore,India
If you're taking SOC-Encounter as a tool, You can use the "dbIsCellSequential" command to find out the sequential elements.
sruthikesh
Newbie level 6
Hyderabad
Hiii, In DC there is a command "report_clock_gating" with this u can find total no. of registers , clock gated registers nd un gated registers.....
sam536
Full Member level 5
Tokyo
sizeof_coll [all_reg ] ; Will give register count
sizeof_coll [all_reg -edge] ; Will give Flop count
sizeof_coll [all_reg -level] ; Will give Latch count
these commands will work in DC /PT
Regards,
Sam
