INFO: chain info -raw
INFO: chain info -active
D:/work/fpga_synplify$ com check
INFO: com check
INFO: Setting up hardware driver ...
INFO: Info: Attempting to connect to the platform USB cable (port=USB2) !
INFO: ok.
INFO: Checking port I/O ...
INFO: Checking communication with the xilinxusb cable and the hardware...
INFO: The hardware is responding correctly.
INFO: ok.
INFO: Checking device chain setup ...
INFO: ok.
INFO: Checking Hardware ID ...
ERROR: Could not find a device which is programmed with an instrumented design:
Device dev_0_XCF32P: Device is not instrumented.
Device dev_1_XC5VLX110: Device is not instrumented.
ERROR:
