How to fill a 2D array in VHDL
a_fetoh
Newbie level 6
Mansoura, Egypt
hello,
how can i insert data into a 2D array element by element.
I tried this code
process(datain,clk)
begin
for j in 0 to 6 loop
for i in 0 to 3 loop
array2d(i)(j) <= datain;
end loop;
end loop;
but all elements are filled with the data in in one clock
i want the array takes a 28 clock to be filled with the data in.
how can i do this ?
It depends on declarations of array2d and datain as well as detailed operational algorithm. Try following constructions
signal cnt:integer range 0 to 31:=0;
process(clk)
begin
if rising_edge(clk) then
   if cnt=27 then
      cnt<=0;
   else
      cnt<=cnt+1;
   end if
   array2d(i) <= datain;
end if;
end process;
process(clk)
begin
if cnt=27 then
cnt<=0;
else
cnt<=cnt+1;
end if
end if;
end process;
but this is vector not array
i've forget something in the code
process(datain,clk)
begin
array2d (i)(j) <= datain;
end loop;
end loop
process(datain,clk)
begin
end loop;
end loop
Ok, the true code is
process(clk)
begin
   if cnt=27 then
      cnt<=0;
   else
      cnt<=cnt+1;
   end if
   array2d(integer(cnt/7))(cnt mod 7) <= datain;
end if;
end process;
integer() is conversation to integer type and mod is division by modulo 7.
I may make mistakes in syntax.
Error:Operator <DIVIDE> must have constant operands or first operand must be power of 2
It is very strange. Integer number must be divided without restrictions. What simulation tool is used?
Other decision is to create two integer counters. The first is in range 0 to 3 and the second is in the range 0 to 6. The first counter must be incremented when the second pass over all range.
Thanks
I've solved it with your idea
signal  i  : integer range 0 to 17 :=0;
signal  j  : integer range 0 to 31 :=31 ;
begin
process(clk)
begin
		if i = 17 then
			i <= 0 ;
		else
			i <= i +1 ;
		end if;
	end if;
end process;
process(clk,i)
begin
			if ( i = 17 and j > 0 ) then
				j <= j - 1 ;
				else
					if (i=17 and j=0) then
			j <= 31;
			end if ;
		end if;
	end if;
end process;
process(clk,i,j)
begin
interleaver(i)(j) <= din;
end if;
end process;
