Mar 11, 2010 #1 M Mustafa_Engineer Full Member level 3 Joined Dec 5, 2007 Messages 161 Helped 23 Reputation 46 Reaction score 13 Trophy points 1,298 Activity points 2,123 Help me please ? how to fed this antenna in HFSS ? please
Mar 12, 2010 #2 TNG Newbie level 5 Joined Feb 25, 2010 Messages 9 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location India Activity points 1,337 Port type in HFSS i have seen such antenna.you need to fed it from the center point. even you can structure a SMA connector at the center of antenna & fed via.
Mar 12, 2010 #3 M monster528 Junior Member level 2 Joined Sep 4, 2009 Messages 23 Helped 5 Reputation 10 Reaction score 4 Trophy points 1,283 Activity points 1,378 Port type in HFSS hellow, using CST mws to simulate this kind of antenna is much more convenience. you can use discrete port.
Mar 19, 2010 #4 A at.sdsu Newbie level 5 Joined Mar 11, 2009 Messages 9 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,330 Re: Port type in HFSS Easy, like the guy above said use an SMA feed. With HFSS its easy but will take an hour or two. If you use EMCoS, its gonna take not more than 10 minutes.
Mar 26, 2010 #5 N neubi Newbie level 3 Joined Mar 25, 2010 Messages 4 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,303 Re: Port type in HFSS mhmm ... and how to feed this antenna in 'real life' - connect the hot end to the center of the antenna! - where to connect the cold side??? br, andy
