How to establish synchronization in serial data transfer?
AdvaRes
At home
Hi all,
I'm finfding difficulties to understand how synchronization can be established in serial data transfert.
Suppose that we have a Transceiver and a Receiver (or Serializer/Deserialize). When the former send a stream of bits the latter is supposed to be able to receive them. Obviously the two devices have each a PLL running at the same frequency F. The receiving mecanism is ok only when the two PLLs synchronize themselves. In the documentation, I found that this is done by sending a set of 0 and 1 (from the Transceiver to the receiver) and this data is used by the CRD circuitery. I have two questions:
1- When there is no data to send, does the transceiver sends continusuosly the set of data 0 and 1 in order to maintain the PLLs synchronized, thus ready to ensure a new data transfert ? Actually the PLL requires a very long time (too many cycles) to lock and I see only this solution to have a good performance in terms of latency.
2- If the reply is no I mean that this synchronization using 0 and 1 bits are used only when we'd like send data, how long we do that and how the receiver recognize that this received signals are for synchronization and not data ?
Thanks in advance.
Re: Synchronization
1.
Usually the data signal is coded to insure transitions and avoid long sequences of 0s or 1s.
Also a scrambler at TX, descrambler at RX is used to randomize the transmitted data.
The transmission is continous if the data link is synchronous - even if no data is to be transmitted a dopping seq is transmitted.
If the transmission is asynchronous when there is nothing to send the TX is off
2. The synch pattern duration - also named PREAMBLE depends on the time required by the PLL to lock. Ex Ethernet 7 bytes.
Generally in asynchronous transmission the time needed for synch needs to be minimized to have a good efficiency. Thus PLL lock time is short and the jitter obtained quite high.
For synchronous transmission the timed needed can be quite long - the synch only hapens once at startup. PLL lock time high, low jitter. The strategy to detect lost synch and reacquire synch is more complex.
    AdvaRes
