.lib file typically has a 7X7 table (input transition, load capacitity). However, there are much more input transition and load capacatity points when performing STA analysis.
The more stages, the more inaccuracy as inaccuracy will be more severe at the later stages.
you have to trust that the people that built the .lib file knew what they were doing. it's not only the number of points that matter, but also the range. I have seen a lot of 9x9 and 11x11 tables recently.
that being said, for you most critical path, you can always export the spice netlist and make sure it matches your STA. it usually matches pretty well as a lot of margin is built into the .lib files.
