How to drive finder relay with 2N3904
jmx66
Member level 5
France
Hi all,
I d'be glad to get advice on this schematic , about driving a finder relay with a NPN 2N3904.
R1 and C1 are only for a delayed power on.
It'a a plug-in module, in case of failure, remove clip and put an other one, no need to desolder like a SSR.....
As usual, queries, if someone could reply, would be really great.
Are values for these resistors correct:
R3 Collector resistor
Rb Base resistor
Rl Led Resistor
I thought to add test points , but finally a green Led will do the job.
- 2N3904 Ic Maxi is about 200mA : Right use for this project, is it a power transistor or must be changed?
-About Led : Iled choice: 10mA for Vf:2,1 V
-I = 90 mA for the coil + 10 mA for the led = 100 mA
-Ic=100 mA with hfe=30 ( mini ) Vcesat=0,3V Ib=3,3mA
-Rc value (15-12-0,3)/ 100 mA= 27 Ohm Rc=27 Ohm
-Rb value for Vbe sat= 0,7 V Rb=( 15-0,7) 3,3mA Rb=4,3KOhm
-R led (12-2,1) / 10 mA R led=1MOhm
Are these basic math correct?
I made a mistake on the schematic, it is not Nominal Output , but must read Power Coil!!!!!!
Thanks a lot.
jm
The potential divider R1/R2 will bring the voltage down to near 10v (not taken into acount the load Rb). Your Ib current will be much less you are calculating (about 1mA). At the junction of R1 and Rb you have a voltage of about 10,7V and an impedance of 10K//20K = 6k6 (consider Rb not connected) driving Rb. The base current will be Ib=(10,7 - Vbe) / (6k6+Rb). Rled should be 1K, not 1M. The remaining calculations seem to be basicaly correct.
Thanks a lot for your reply.
Best regards.
jm
Why is R3 there? It doesn't make sense.
What is R2 and the diode for? Again, I don't see the point. If it is to discharge the base capacitor when the power is removed then a diode to the positive rail should be used.
As pointed out earlier, your base current will be a lot lower than you think. I would remove R2, Rb and the diode and size R1 for the base current. Then increase the capacitor to suit.
Overall it is not a great circuit. The turn on will be slow and 'soft'. I would prefer something with a positive switchover.
Keith
Reactions: jmx66
    jmx66
.Hi,
I need to lower voltage for relay coil 9,3 13,1 V
I have changed the circuit above, and replaced 2N3904 by 2N2222.
With advices from experienced members of this forum,I redraw my draft, this is a result, don't know , if it is really correct....
for Ib=15 mA Ic= 150 mA Vbe sat Maxi 1,3 V
Schematic-V1
Changes: R1 to 1 KOhm and R2 to 10 KOhm
C1 1500 µF
Req : 1Kohm // 10 Kohm about 1 KOhm
Maths for Rb: Ve = 15 x ( 10 / 11 ) Ve= 13,7 Volts
Choice for Ib: 10 mA 13,7 -1,3 = ( Req +Rb ) x 10 mA
Rb = 240 Ohm
Schematic-V2
Diode to discharge C1 added .
Removed 20 KOhm resistor
Added C1 1500 µF
Now for Rb 15 -1,3 = ( Rb x 10 mA) Rb= 1,4 KOhm
In fact, i need a power on delay of about 1 second.
I agree, it is not a great circuit, and that's why i need advices!!!!
Best regards.
jm**broken link removed**
  • 2N2222-Low-Power-Bipolar-Transistors.pdf
Why not just use a 12V regulator up front and a 555 monostable for the delay and go from there?
Reactions: jmx66
    jmx66
Thanks for your reply.
In fact, i thought to add a 7812 after a 7815, but discard this solution; not enough place .
I wanted something simpler than above.
And for the 555 , with Kicad - I'm not very experienced with this soft - it seemed too difficult to route thin routes between pins.
Best regards.
jm
It's reasonable to target to a minimum part count and size circuit, thus I think the design is basically good. I would however prefer a MOSFET or darlington transistor to get rid of the unconvenient large capacitor. If you don't have it at hand, a darlington circuit of two individual transistors would work as well.
Reactions: jmx66
    jmx66
Hi all,
After searching in datasheet of Darlington - FvM's advice -, found TIP110 and draw another schematic.
Added also a diode, after Keith's advice.
Data for TIP110
Maximum ratings Base current 50 mA
On characteristics
Vce sat = 2,5 Maxi Base-Emitter On Voltage 2,8 Maxi
hfe: 500 to 1000 minimum
Queries:
Is R3 Value correct? ( 15 -2,5 ) / 10 mA \approx R3 = 125 Ohm
Idem for Rb Ve = 10 V
Rb * 10mA = 10 - 2,8
Rb = 600 Ohm
I know the draft is not a high level circuit, but the question is :
Should it work ?
I know also that darlington symbol is different from a transistor.....
Thanks a lot.
jm
  • Multicomp-TIP110-TIP115-Darlington-Transistors-.pdf
Rb isn't needed at all, I think. R1 and R2 can be higher resistance with a darlington, and C1 possibly smaller. R3 has to be choosen such, that at least the minimal engage voltage for the relay is achieved, better, you target nearer to the nominal voltage to have some margin. Also the LED current, that hasn't been specified, must be considered. The previous value of 27 ohm results in an almost exact relay voltage of 12 V. With a darlington, the transistor saturation voltage is considerably higher, so 27 ohm isn't bad.
Reactions: jmx66
    jmx66
Hi all,
Thanks for your replies, first.
Made changes to previous schematic: mostly removed Rb and resistors values modified.
Maths for R3:
V coil = 9,3 V ( 15 - 9,3 - 2,5 )/ 100 mA R3≈ 30 Ohm
V coil = 12 V ( 15 - 12 - 2,5 ) / 100 mA R3 ≈ 5 Ohm
Choice : 5 Ohm
About led :
I led = 10 mA
Vf = 2,1 V (12 - 2,1 ) / 100mA R led ≈ 100 Ohm
Now for R1 and R2
R1 = 10 KOhm
R2 = 20 KOhm
Req = 300 / 40 Req = 7,5 KOhm
Ve = ( 15 x 30 ) / 40 Ve = 11,25 V Ib= 1,16 mA
For R1= 10 KOhm
R2= 43 KOhm
Req= 8,11 KOhm Ve = 12,16V Ib= 1,2mA
I only want to know if Ib is sufficient enough to drive 100 mA on the coil?
Best regards.
jm
